Introducción
Use this guide to replace your mini's speaker. Replacing the speaker requires removal of the logic board.
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
Remove the following three screws:
One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
One 16.2 mm T6 Torx screw
One 26 mm T6 Torx standoff
Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
Remove the following two screws securing the speaker to the logic board assembly:
One 4.2 mm T6 Torx
One 3.7 mm T6 Torx
2 personas más completaron esta guía.
