Introducción
Completely replacing the logic board requires removal of the logic board itself as well as all components attached to it.
Qué necesitas
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 or T9 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
Remove the following three screws:
One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
One 16.2 mm T6 Torx screw
One 26 mm T6 Torx standoff
Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
Remove the following two screws securing the speaker to the logic board assembly:
One 4.2 mm T6 Torx
One 3.7 mm T6 Torx
Use the flat end of a spudger to pry the antenna connectors up off the AirPort/Bluetooth board.
Use the tip of a spudger to carefully pry the PRAM battery up and out of its holder on the logic board.
Remove the PRAM battery and set it aside.
Carefully lift the heat sink off the logic board, minding the thermal sensor cable that may get caught.
If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
19 personas más completaron esta guía.
7 comentarios
I'm confused, in step 11 the antenna plate is removed from the case, then in step 12 the bare logic board is out. What happened to the rest of the removal process?
Hey sorry about that, the guide was missing a prerequisite. I went through and made sure all the guides are OK. It should be fixed now. Good catch!
I’d really like to know this as well if anyone knows
I'd like to know also
