Introducción
How to remove the upper case.
Partes
No se requieren partes.
Power down your Mac mini, disconnect all of the cables, and flip it over.
  • Power down your Mac mini, disconnect all of the cables, and flip it over.
  • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
  • The Jimmy should reach a stop about 3/8" down.
Agregar Comentario
Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
  • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
  • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
Agregar Comentario
  • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
  • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
Agregar Comentario
  • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
Agregar Comentario
  • Keep working around the perimeter, freeing the clips along the final edge.
Agregar Comentario
  • Flip the Mac mini back over and lift the top housing off of the lower housing.
Agregar Comentario
Conclusión
9 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 24/09/09
1 Reputación
621 Guías creadas
those Putty Knifes are:
too smal
too sharp
too expensive.
Better use a 100mm broad Spatula; (opens all the claws in on step)
out of plastic is good enough and cheap.
And use two of them at one time.
spatula - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 20
Todo El Tiempo: 9,191
