Introducción
Upgrade or replace the combo or SuperDrive.
Power down your Mac mini, disconnect all of the cables, and flip it over.
  • Power down your Mac mini, disconnect all of the cables, and flip it over.
  • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
  • The Jimmy should reach a stop about 3/8" down.
Agregar Comentario
Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
  • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
  • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
Agregar Comentario
  • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
  • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
Agregar Comentario
  • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
Agregar Comentario
  • Keep working around the perimeter, freeing the clips along the final edge.
Agregar Comentario
  • Flip the Mac mini back over and lift the top housing off of the lower housing.
Agregar Comentario
  • If your mini does not have Airport installed, then skip this step.
  • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
Agregar Comentario
  • Remove the yellow tape securing the power button cable to the black plastic framework.
Agregar Comentario
  • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
Agregar Comentario
  • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
I just put in a 1G RAM chip that just came in the mail from iFixit. And though I followed every step this step (removing the HD, cooling fan, and drive unit) was not needed. I put the chip in, put everything back in place then removed and replaced the RAM with no problems. So it would seem that for a/my PowerPC Mac Mini (I have a 1.33 Ghz processor) it was not a needed step.
mbob518 - Contestar
BTW, it took about 15 - 20 min even with my experimentation.
Cita de mbob518:
mbob518 - Contestar
  • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
  • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
havin a hard time with step 9. i don't really see how I'm supposed to remove the Wi-Fi/Bluetooth cables from the Airport card. They seem to be soldered in! is there a twisting motion involved? I just don't wanna mess it up more than i already did with my putty knife haha!
chris - Contestar
Same problem here on this one. There seems to be no way to get them off and I can't seem to unscrew this thing. I think this otherwise great guide should be more precise about how to get the antenna cables out of the way :-(
sebastian.patting - Contestar
  • Remove the four silver Phillips screws attaching the optical drive to the black plastic framework (two on each side).
Agregar Comentario
  • If your mini does not have a Bluetooth board, you may skip the following step.
  • Remove the yellow tape securing the Bluetooth antenna cable to the black plastic framework.
  • Lift the silver Bluetooth antenna board out of its slot.
Agregar Comentario
  • The cables you're about to remove are very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
  • Flip the mass storage assembly over and disconnect the speaker and fan cables from the interface board.
Agregar Comentario
  • Flip the mass storage assembly back over. Grasp either side of the plastic framework and push the optical drive away from you with your thumbs on either side of the bezel until you hear it pop free.
  • Lift the optical drive and attached interface board up from the assembly.
Agregar Comentario
  • Remove the two silver Phillips screws connecting the interface board to the optical drive.
Agregar Comentario
  • Grasp either side of the interface board and wiggle it free of the optical drive.
Agregar Comentario
Conclusión
18 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 24/09/09
1 Reputación
774 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 4
Últimos 30 Días: 19
Todo El Tiempo: 20,680
