Saltar al contenido principal
Mac Pro First Generation RAM Replacement
  1. Mac Pro First Generation RAM Replacement, Case Panel: paso 1, imagen 1 de 1
    • Lift the lever to unlock the case.
  2. Mac Pro First Generation RAM Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
  3. Mac Pro First Generation RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Locate the two RAM trays at the bottom of the Mac Pro.
  4. Mac Pro First Generation RAM Replacement: paso 4, imagen 1 de 2 Mac Pro First Generation RAM Replacement: paso 4, imagen 2 de 2
    • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
    • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
  5. Mac Pro First Generation RAM Replacement: paso 5, imagen 1 de 3 Mac Pro First Generation RAM Replacement: paso 5, imagen 2 de 3 Mac Pro First Generation RAM Replacement: paso 5, imagen 3 de 3
    • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
    • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
Conclusión
22 personas más completaron esta guía.
Andrew Kim
Miembro Desde 10/12/14
1,263 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-24, Maness Fall 2014 Miembro de Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Miembros
13 Guías creadas
2 comentarios
What is the name/or type of memory chip to use in the MacPro 2008.
Curtis - Contestar
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
coopernewlyn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 45
Todo El Tiempo: 20,548
