Saltar al contenido principal
Mac Pro First Generation Optical Drive Replacement
Qué necesitas
  1. Mac Pro First Generation Optical Drive Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Lift the lever to unlock the case
  2. Mac Pro First Generation Optical Drive Replacement: paso 2, imagen 1 de 1
    • Remove the side panel of the Mac Pro
  3. Mac Pro First Generation Optical Drive Replacement: paso 3, imagen 1 de 3 Mac Pro First Generation Optical Drive Replacement: paso 3, imagen 2 de 3 Mac Pro First Generation Optical Drive Replacement: paso 3, imagen 3 de 3
    • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
  4. Mac Pro First Generation Optical Drive Replacement: paso 4, imagen 1 de 1
    • Firmly hold each of the two connectors and pull them out of their respective sockets.
  5. Mac Pro First Generation Optical Drive Replacement: paso 5, imagen 1 de 2 Mac Pro First Generation Optical Drive Replacement: paso 5, imagen 2 de 2
    • Unscrew the shown two 6-32 type screws on each side of the optical drive.
  6. Mac Pro First Generation Optical Drive Replacement: paso 6, imagen 1 de 2 Mac Pro First Generation Optical Drive Replacement: paso 6, imagen 2 de 2
    • Firmly grasp the optical drive and pull it out of its enclosure.
Conclusión
21 personas más completaron esta guía.
Derek Chan
Miembro Desde 10/13/14
1,416 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-24, Maness Fall 2014 Miembro de Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Miembros
13 Guías creadas
10 comentarios
Thanks! It had been a long time since I'd been inside my towers! Easy-peasy!
Janie Wilson-Cook - Contestar
I am having problems with the new optical drive not being able to eject and close without my help. Any thoughts?
footeking - Contestar
Did you take off the front of the tray?
nbeijer -
Awesome!!! Worked like a charm! Drive is totally busted. Do you have a link or a suggestion for an optical drive for a late 2009 Mac pro? Thanks either way!
Jay Haser - Contestar
The unit holding the optical drive will NOT pull out at all and I and really pulling on it and wiggling it. All other videos show it popping out with little force. What am I doing wrong?
pipevape - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 51
Todo El Tiempo: 16,866
