Introducción
Removing and/or replacing the Front Fan Assembly of a Mac Pro (Early 2008).
Herramientas
Partes
No se especificaron partes.
Type: Serial Attached SCSI (SAS) or Serial ATA (SATA) 3 Gb/s
Width: 3.9 inches (102 mm)
Depth: 5.7 inches (147 mm)
Height: 1.0 inch
This procedure explains how to remove a standard card and a card that includes a booster cable. Before you can remove either type of card, however, you must first loosen the two captive screws that secure the PCI bracket to the enclosure and remove the bracket.
Disconnect the booster cable(s) from the logic board.
Release the small locking clip at the front of the card’s logic board connector by pushing the clip up toward the media shelf.
Holding the card by the top corners, gently pull up the card and remove it from its expansion slot.
Place the fingers of one hand under the lip of the heatsink cover nearest the logic board. Lift the lip slightly toward the media shelf to release the tabs and magnets under the top face of the cover.
With your fingers still under the cover’s bottom lip, lift the cover straight up to release the remaining tabs and magnets under the front face of the cover
Remove the cover from the enclosure.
Using a long-handled, magnetized #1 Phillips screwdriver, remove the screw at the top rear of the front fan assembly that mounts the assembly to the logic board.
21 personas más completaron esta guía.
