Saltar al contenido principal
Mac Mini Late 2014 PRAM Battery Replacement
Qué necesitas
  1. Mac Mini Late 2014 PRAM Battery Replacement, Logic Board Assembly: paso 1, imagen 1 de 1
    • Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
  2. Mac Mini Late 2014 PRAM Battery Replacement: paso 2, imagen 1 de 2 Mac Mini Late 2014 PRAM Battery Replacement: paso 2, imagen 2 de 2
    • Remove the SATA cable connector bracket.
  3. Mac Mini Late 2014 PRAM Battery Replacement: paso 3, imagen 1 de 2 Mac Mini Late 2014 PRAM Battery Replacement: paso 3, imagen 2 de 2
    • Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
  4. Mac Mini Late 2014 PRAM Battery Replacement: paso 4, imagen 1 de 2 Mac Mini Late 2014 PRAM Battery Replacement: paso 4, imagen 2 de 2
    • Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
  5. Mac Mini Late 2014 PRAM Battery Replacement: paso 5, imagen 1 de 1
    • The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
  6. Mac Mini Late 2014 PRAM Battery Replacement: paso 6, imagen 1 de 2 Mac Mini Late 2014 PRAM Battery Replacement: paso 6, imagen 2 de 2
    • Remove the PCIe SSD cable bracket.
  7. Mac Mini Late 2014 PRAM Battery Replacement: paso 7, imagen 1 de 2 Mac Mini Late 2014 PRAM Battery Replacement: paso 7, imagen 2 de 2
    • Lift the PCIe SSD connector up off its socket.
  8. Mac Mini Late 2014 PRAM Battery Replacement: paso 8, imagen 1 de 1
    • Remove the single 16 mm T6 screw securing the logic board.
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
  9. Mac Mini Late 2014 PRAM Battery Replacement: paso 10, imagen 1 de 3 Mac Mini Late 2014 PRAM Battery Replacement: paso 10, imagen 2 de 3 Mac Mini Late 2014 PRAM Battery Replacement: paso 10, imagen 3 de 3
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the removal tool makes contact with the opening in the rear case.
    • Remove the Mac mini Logic Board Removal tool.
  10. Mac Mini Late 2014 PRAM Battery Replacement: paso 11, imagen 1 de 2 Mac Mini Late 2014 PRAM Battery Replacement: paso 11, imagen 2 de 2
    • Pull the DC-In cable connector straight out of its socket on the logic board.
  11. Mac Mini Late 2014 PRAM Battery Replacement: paso 12, imagen 1 de 2 Mac Mini Late 2014 PRAM Battery Replacement: paso 12, imagen 2 de 2
    • Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
  12. Mac Mini Late 2014 PRAM Battery Replacement, Peel tape: paso 13, imagen 1 de 1
    • Now the logic board is removed, turn the board over.
    • Peel the tape
  13. Mac Mini Late 2014 PRAM Battery Replacement, Remove old battery: paso 14, imagen 1 de 2 Mac Mini Late 2014 PRAM Battery Replacement, Remove old battery: paso 14, imagen 2 de 2
    • Use a spudger or small screwdriver to push the battery to the side and it will flip out
  14. Mac Mini Late 2014 PRAM Battery Replacement, Put the tape back: paso 15, imagen 1 de 1
    • Insert the replacement battery
    • Put the tape back the best you can
Conclusión
While you can use the CR2032 the BR2032 is recommended as it has a higher heat tollerance and the type fitted by Apple. The chemical make up is also different. To reassemble your device, follow these instructions in reverse order.
12 personas más completaron esta guía.
Tom
Miembro Desde 05/04/14
1,582 Reputación
4 Guías creadas
3 comentarios
I can’t find a way to contact you anywhere on your site but your fix for installing windows on a mac worked for me. I had been trying to get it to work for 2 days. Deleted my OSX install and everything. Deleting the second EFI partition is what it was. Nowhere else said that but your blog. So man, thanks and keep it up.
Jordan - Contestar
No problem, your welcome. Thanks for your help too, you made me realise I broke the website comments during an upgrade.
Tom -
Thanks! This guide helped a lot! To folks doing this replacement, the tape covering the battery comes up fairly easy if you first use your tweezers to gently lift the three tabs on the sides of the battery housing, then it should come off in one piece.
Nick - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 38
Ultimos 30 días: 186
Todo El Tiempo: 7,598
