Saltar al contenido principal
Este desmontaje no es una guía de reparación. Para reparar tu Mac mini (2024), utiliza nuestros manuales de servicio .
  1. Mac Mini (2024) Chip ID, Main Board Side 1: paso 1, imagen 1 de 2 Mac Mini (2024) Chip ID, Main Board Side 1: paso 1, imagen 2 de 2
    • Apple APL1206/339S01548 E M4 deca-core applications processor w/ GPU
    • Micron MT62F1G64D4AS-026 XT:C 8 GB LPDDR5 SDRAM Memory
    • Apple APL1066/343S00710 power management
    • Apple APL1067/343S00683 ? power management
    • Likely Apple U0P4F7-Y2 Thunderbolt 4 controller
    • Winbond W25Q64NE 8 MB serial NOR flash memory
    • Likely Infineon CYUSB2408 USB level shifter
  2. Mac Mini (2024) Chip ID, Main Board Side 1: paso 2, imagen 1 de 1
    • Winbond W25X40CL 4 Mb serial NOR flash memory
    • Texas Instruments TPS628502 2 A / adj. step-down converter
    • Analog Devices DC-DC converter
    • Texas Instruments TPS715A01 80 mA / adj. LDO regulator
    • Texas Instruments TPS2559 power distribution switch
    • Texas Instruments INA190A2 bidirectional current sense amplifier
    • Texas Instruments TLV7021 single comparator
  3. Mac Mini (2024) Chip ID: paso 3, imagen 1 de 2 Mac Mini (2024) Chip ID: paso 3, imagen 2 de 2
    • Likely Parade Technologies PS190 DisplayPort to HDMI converter
    • Genesys Logic GL3590-TBYS2 3 USB Type-C SuperSpeed+ & 3 USB Type-A SuperSpeed+ hub controller
    • Macronix MX25V2035FZUI 2 Mb serial NOR flash memory
    • Texas Instruments SN26A23 USB Type-C controller
    • GigaDevice GD25Q80E 1 MB serial NOR flash memory
    • Broadcom BCM57762 gigabit ethernet controller
  4. Mac Mini (2024) Chip ID: paso 4, imagen 1 de 1
    • Apple APL5791/343S00709 power management
    • Renesas multiphase controller
    • Cirrus Logic CS42L84A audio codec
    • Texas Instruments SN012776B0 audio amplifier
    • Texas Instruments TPS621371 step-down converter
    • Likely Renesas PWM DC-DC converter controller
  5. Mac Mini (2024) Chip ID: paso 5, imagen 1 de 1
    • onsemi NCP380LMU05AATBG power distribution switch
    • Likely Renesas mixed signal array
    • Texas Instruments TLV75801P 500 mA / adj. LDO regulator
    • Texas Instruments INA190A3 bidirectional current sense amplifier
    • Texas Instruments TLV7011 single comparator
    • Texas Instruments TLV9051 single operational amplifier
  6. Mac Mini (2024) Chip ID, SSD Side 1: paso 6, imagen 1 de 2 Mac Mini (2024) Chip ID, SSD Side 1: paso 6, imagen 2 de 2
    • SanDisk SDMVGKLK2 128G 128 GB NAND flash
  7. Mac Mini (2024) Chip ID, SSD Side 2: paso 7, imagen 1 de 2 Mac Mini (2024) Chip ID, SSD Side 2: paso 7, imagen 2 de 2
    • Apple 338S00600-A0 power management
    • Texas Instruments TPS62180 6 A synchronous buck converter
  8. Mac Mini (2024) Chip ID, Wireless Board: paso 8, imagen 1 de 2 Mac Mini (2024) Chip ID, Wireless Board: paso 8, imagen 2 de 2
    • Likely USI 339S01162 Bluetooth & WiFi module
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 19
Ultimos 7 días: 212
Ultimos 30 días: 961
Todo El Tiempo: 5,143
