Saltar al contenido principal
MSI VR601 WiFi card Replacement
Qué necesitas
  1. MSI VR601 WiFi card Replacement, Open the back cover: paso 1, imagen 1 de 2 MSI VR601 WiFi card Replacement, Open the back cover: paso 1, imagen 2 de 2
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: paso 2, imagen 1 de 2 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: paso 2, imagen 2 de 2
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: paso 3, imagen 1 de 1
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
Conclusión
Geir Ove Andersen
Miembro Desde 06/06/22
7,485 Reputación
5 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
312 Miembros
1,330 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 86
