Saltar al contenido principal
MSI PR600 MS-16372 Key Replacement
Qué necesitas
  1. MSI PR600 MS-16372 Key Replacement, Key: paso 1, imagen 1 de 1
    • Before you begin this replacement, make sure to turn the computer off to prevent future problems from occurring.
    • Start by flipping the laptop upside down and shake it gently to release excess debris.
  2. MSI PR600 MS-16372 Key Replacement: paso 2, imagen 1 de 1
    • Place flathead screwdriver underneath the faulty key.
    • Lift the flathead screwdriver upwards until you hear a click and it releases off the keyboard.
  3. MSI PR600 MS-16372 Key Replacement: paso 3, imagen 1 de 1
    • Gently brush off any loose particles that could be found underneath the key.
  4. MSI PR600 MS-16372 Key Replacement: paso 4, imagen 1 de 1
    • Align key to the center of the button and press down until you hear it click.
    • If you do not apply enough pressure the key will not fully reattach, so make sure you press hard enough.
Conclusión
Lauren Mewes
Miembro Desde 10/21/18
361 Reputación
3 Guías creadas
Equipo
UC Davis, Team S4-G8, Lore Fall 2018 Miembro de UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 297
