Saltar al contenido principal
MSI PR600 MS-16372 Battery Replacement
  1. MSI PR600 MS-16372 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • First, turn off the computer and unplug the power cord.
    • If laptop is not unplugged from the power cord, you could be at risk of electric shock.
  2. MSI PR600 MS-16372 Battery Replacement: paso 2, imagen 1 de 1
    • Flip laptop over so that you are looking at the bottom of the laptop.
    • Put your left pointer finger on the switch labeled "Battery lock" and your right pointer finger on the switch labeled "Release".
  3. MSI PR600 MS-16372 Battery Replacement: paso 3, imagen 1 de 1
    • Switch the tab labeled "Battery lock" to the unlocked position.
    • Slide the tab labeled "Release" to the right and hold it down.
    • While holding the "Release" tab to the right, slide the battery out with your left hand.
Conclusión
Lauren Mewes
Miembro Desde 10/21/18
361 Reputación
3 Guías creadas
Equipo
UC Davis, Team S4-G8, Lore Fall 2018 Miembro de UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 305
