Saltar al contenido principal
MSI PE70 6QE-035US speaker Replacement
Qué necesitas
  1. MSI PE70 6QE-035US speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US speaker Replacement: paso 2, imagen 1 de 2 MSI PE70 6QE-035US speaker Replacement: paso 2, imagen 2 de 2
    • After you remove the back panel, you should now see the 3 speakers.
    • We will start with the bottom most speaker.
  3. MSI PE70 6QE-035US speaker Replacement: paso 3, imagen 1 de 2 MSI PE70 6QE-035US speaker Replacement: paso 3, imagen 2 de 2
    • Using the ifixit opening tool, remove the speaker by gently unplugging its cord from the motherboard. Be sure to unplug the cord in the direction shown by the arrow.
    • After the cord has been unplugged, the speaker should now be able to be lifted out.
  4. MSI PE70 6QE-035US speaker Replacement: paso 4, imagen 1 de 3 MSI PE70 6QE-035US speaker Replacement: paso 4, imagen 2 de 3 MSI PE70 6QE-035US speaker Replacement: paso 4, imagen 3 de 3
    • These two speakers will be taken out together because they are held in by the same cord.
    • Once you have unplugged the cord, both speakers should be able to be lifted out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 63
