Saltar al contenido principal
MSI PE70 6QE-035US Fan Replacement
Qué necesitas
  1. MSI PE70 6QE-035US Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US Fan Replacement: paso 2, imagen 1 de 1
    • after the back of the laptop is off, unscrew all the black and silver screws holding in the heat sink and fan covers.
    • There should be 8 silver, 6 black, and 14 screws in total.
  3. MSI PE70 6QE-035US Fan Replacement: paso 3, imagen 1 de 2 MSI PE70 6QE-035US Fan Replacement: paso 3, imagen 2 de 2
    • disconnect the wires that go from the fans to the motherboard.
    • then remove the fans from the mother board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 81
