Saltar al contenido principal
MSI MS-1782 Speaker Assembly Replacement
Qué necesitas
  1. MSI MS-1782 Speaker Assembly Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Speaker Assembly Replacement: paso 2, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 2, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 2, imagen 3 de 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Speaker Assembly Replacement, Cooling Assembly: paso 3, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement, Cooling Assembly: paso 3, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement, Cooling Assembly: paso 3, imagen 3 de 3
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  4. MSI MS-1782 Speaker Assembly Replacement: paso 4, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 4, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 4, imagen 3 de 3
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  5. MSI MS-1782 Speaker Assembly Replacement: paso 5, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 5, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 5, imagen 3 de 3
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  6. MSI MS-1782 Speaker Assembly Replacement: paso 6, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 6, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 6, imagen 3 de 3
  7. MSI MS-1782 Speaker Assembly Replacement: paso 7, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 7, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 7, imagen 3 de 3
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  8. MSI MS-1782 Speaker Assembly Replacement: paso 8, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 8, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 8, imagen 3 de 3
    • Gently lift the heat sink and then pull forwards towards you.
  9. MSI MS-1782 Speaker Assembly Replacement, Battery: paso 9, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement, Battery: paso 9, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement, Battery: paso 9, imagen 3 de 3
    • Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
    • Gently disconnect the cable connecting the M.2 caddy to the motherboard.
  10. MSI MS-1782 Speaker Assembly Replacement: paso 10, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 10, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 10, imagen 3 de 3
    • Remove the 3.6 mm screw holding the M.2 caddy in place using a JIS #1 screwdriver.
  11. MSI MS-1782 Speaker Assembly Replacement: paso 11, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 11, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 11, imagen 3 de 3
    • Gently disconnect the two blue ribbons.
  12. MSI MS-1782 Speaker Assembly Replacement: paso 12, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 12, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 12, imagen 3 de 3
    • Remove the 5.1 mm screw holding in the disk reader using a JIS #1 screwdriver.
    • Use an iFixit opening tool to push the back of the disk reader to push it out of the laptop's chassis.
  13. MSI MS-1782 Speaker Assembly Replacement: paso 13, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 13, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 13, imagen 3 de 3
    • Gently pull the disc reader out of the laptop.
    • Lift the plastic cover and disconnect the cable connected next to the speaker.
  14. MSI MS-1782 Speaker Assembly Replacement: paso 14, imagen 1 de 1
    • Remove the five 5 mm screws holding the frame in place using a JIS #1 screwdriver.
  15. MSI MS-1782 Speaker Assembly Replacement: paso 15, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 15, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 15, imagen 3 de 3
    • Pry up on the battery frame with an opening tool and unclip from the main chassis, working your way around the laptop.
    • To remove the battery, pry up on it to unstick the adhesive.
    • A little Isopropyl alcohol under the battery can help unstick it from the frame.
  16. MSI MS-1782 Speaker Assembly Replacement, Speaker Assembly: paso 16, imagen 1 de 2 MSI MS-1782 Speaker Assembly Replacement, Speaker Assembly: paso 16, imagen 2 de 2
    • Pull the left speaker out, following the wire, unclipping it as you go to the next.
  17. MSI MS-1782 Speaker Assembly Replacement: paso 17, imagen 1 de 2 MSI MS-1782 Speaker Assembly Replacement: paso 17, imagen 2 de 2
    • Pull the right speaker out. Unclip the wire as you go, now completely removing both speakers.
  18. MSI MS-1782 Speaker Assembly Replacement: paso 18, imagen 1 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 18, imagen 2 de 3 MSI MS-1782 Speaker Assembly Replacement: paso 18, imagen 3 de 3
    • Unplug the subwoofer and lift vertically to remove.
Conclusión
A'kia
Miembro Desde 03/08/23
193 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 103
