Saltar al contenido principal
MSI MS-1782 Back Cover Replacement
Qué necesitas
  1. MSI MS-1782 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Back Cover Replacement: paso 2, imagen 1 de 3 MSI MS-1782 Back Cover Replacement: paso 2, imagen 2 de 3 MSI MS-1782 Back Cover Replacement: paso 2, imagen 3 de 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 233
