Saltar al contenido principal
MSI GT75VR 7RF Titan Pro RAM Card Replacement
Qué necesitas
  1. MSI GT75VR 7RF Titan Pro RAM Card Replacement, RAM Card: paso 1, imagen 1 de 1
    • Unscrew each of the four screws using the Phillips #0 head on the back of the laptop case. The screws are 0.5 inches in length.
  2. MSI GT75VR 7RF Titan Pro RAM Card Replacement: paso 2, imagen 1 de 2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: paso 2, imagen 2 de 2
    • Pop the back cover off of the laptop using the black nylon spudger.
  3. MSI GT75VR 7RF Titan Pro RAM Card Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery cable.
  4. MSI GT75VR 7RF Titan Pro RAM Card Replacement: paso 4, imagen 1 de 2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: paso 4, imagen 2 de 2
    • Pry the battery pack up with the black nylon spudger.
  5. MSI GT75VR 7RF Titan Pro RAM Card Replacement: paso 5, imagen 1 de 1
    • Pop the metal tabs on each side of the RAM using the black nylon spudger.
  6. MSI GT75VR 7RF Titan Pro RAM Card Replacement: paso 6, imagen 1 de 1
    • Lift and remove RAM card by hand. Replace each RAM card and test them individually. If your computer encounters a RAM error with only one card inserted, you can confirm that card is corrupted.
Conclusión
Jack Crumpton
Miembro Desde 08/31/18
241 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 659
