Saltar al contenido principal
Introducción
How to access, locate, and replace your MSI GT75VR 7RF Titan Pro cooling fan if it breaks.
Partes
No se especificaron partes.
  1. Using the Phillips #0 screwdriver, unscrew each of the four screws  on the back of the laptop case. The screws are 0.5 inches long.
    • Using the Phillips #0 screwdriver, unscrew each of the four screws on the back of the laptop case. The screws are 0.5 inches long.
  2. Pop the back cover off of the laptop using the black nylon spudger. Pop the back cover off of the laptop using the black nylon spudger.
    • Pop the back cover off of the laptop using the black nylon spudger.
  3. Disconnect the battery cable. Pry the battery out using the black nylon spudger. Disconnect the battery cable. Pry the battery out using the black nylon spudger.
    • Disconnect the battery cable. Pry the battery out using the black nylon spudger.
  4. Using the Phillips #0 screwdriver, unscrew the two black 0.25 inch screws located on the sides of the cooling fan. Unplug the unit.
    • Using the Phillips #0 screwdriver, unscrew the two black 0.25 inch screws located on the sides of the cooling fan.
    • Unplug the unit.
Conclusión
Jack Crumpton
Miembro Desde 31/08/18
241 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 386
