Saltar al contenido principal
MSI GT72 2QE Dominator Pro CD Drive Replacement
Qué necesitas
  1. MSI GT72 2QE Dominator Pro CD Drive Replacement, CD Drive: paso 1, imagen 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement, CD Drive: paso 1, imagen 2 de 2
    • Remove the indicated seven (7) 6 mm Phillips #0 screws for the back cover.
    • The same PHO screwdriver bit can be used throughout all the steps.
  2. MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 2, imagen 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 2, imagen 2 de 2
    • Lift the back cover using the tab to expose the hardware beneath.
  3. MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 3, imagen 1 de 3 MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 3, imagen 2 de 3 MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 3, imagen 3 de 3
    • Remove the indicated 5mm Phillips #0 screw.
    • This is the only screw holding the CD drive in place. Do not lose it.
  4. MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 4, imagen 1 de 1
    • Using the plastic opening tool, pull out the CD drive.
  5. MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 5, imagen 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 5, imagen 2 de 2
    • Remove the indicated 4mm Phillips #0 screw and metal hinge.
  6. MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 6, imagen 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 6, imagen 2 de 2
    • Remove the three (3) indicated 2mm Phillips #0 screws.
  7. MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 7, imagen 1 de 2 MSI GT72 2QE Dominator Pro CD Drive Replacement: paso 7, imagen 2 de 2
    • Lift metal cover gently, using the tab like indent located where the arrow is pointed.
    • This should expose the inside of the CD drive.
Conclusión
3 personas más completaron esta guía.
Ankit Maurya
Miembro Desde 04/18/17
201 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S17-G2, Banghart Spring 2017 Miembro de Cal Poly, Team S17-G2, Banghart Spring 2017
CPSU-BANGHART-S17S17G2
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,758
