Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This troubleshooting page will assist in the replacment of the hard drive of the MSI GT62VR 6RD Dominator.
This guide has no special requirements or hazards.
  1. Remove the six screws on the back plate of the laptop using a JIS #0 screwdriver. Remove the six screws on the back plate of the laptop using a JIS #0 screwdriver.
    • Remove the six screws on the back plate of the laptop using a JIS #0 screwdriver.
  2. Insert a plastic opening tool into the seam of the back cover Pry the cover up until clips release. Slide the plastic opening tool around the laptop until cover is fully removed.
    • Insert a plastic opening tool into the seam of the back cover
    • Pry the cover up until clips release.
    • Slide the plastic opening tool around the laptop until cover is fully removed.
  3. Remove the two screws securing the hard drive to the laptop. Lightly lift the hard drive up by grasping the silver bracket that secures it to the laptop.
    • Remove the two screws securing the hard drive to the laptop.
    • Lightly lift the hard drive up by grasping the silver bracket that secures it to the laptop.
    • Wiggle it backwards slowly until it is unplugged.
    • Slide out from under the cover towards the battery.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 384
