Saltar al contenido principal
MSI GS70 Hard Drive Replacement
Qué necesitas
  1. MSI GS70 Hard Drive Replacement, Remove the Backplate: paso 1, imagen 1 de 2 MSI GS70 Hard Drive Replacement, Remove the Backplate: paso 1, imagen 2 de 2
    • Using your JIS #1, locate and remove all screws from the backplate.
    • When all the screws are removed, proceed to remove the backplate. The hard drive will be located right next to the battery.
  2. MSI GS70 Hard Drive Replacement, Remove the Hard Drive Spacer: paso 2, imagen 1 de 2 MSI GS70 Hard Drive Replacement, Remove the Hard Drive Spacer: paso 2, imagen 2 de 2
    • Locate the black rubber spacer
    • Remove the spacer by gently pulling the flap
  3. MSI GS70 Hard Drive Replacement, Disconnect your Hard Drive: paso 3, imagen 1 de 1
    • With two hands slide the Hard Drive to the left.
  4. MSI GS70 Hard Drive Replacement, Remove the Hard Drive: paso 4, imagen 1 de 2 MSI GS70 Hard Drive Replacement, Remove the Hard Drive: paso 4, imagen 2 de 2
    • Carfully lift up the Hard Drive using your Spudger.
    • Next, pull up your hard drive from the battery end and proceed to remove the hard drive
Conclusión
11 personas más completaron esta guía.
2 comentarios
The screws on my machine were Philips not torx don't know if it is different or has changed at all but all internal and external were Phillips
rambo33hockey - Contestar
bonjour
comment accéder au disque dur msata sur le msi gs 70
Vivabzh côtes d'armors - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 40
Todo El Tiempo: 16,092
