Saltar al contenido principal
MSI GS66 Stealth 11UE-007 Speakers Replacement
Qué necesitas
  1. MSI GS66 Stealth 11UE-007 Speakers Replacement, Battery: paso 1, imagen 1 de 1
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device.
  2. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 2, imagen 1 de 1
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
  3. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 3, imagen 1 de 1
    • Remove eight 10 mm Phillips #1 screws.
  4. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 4, imagen 1 de 1
    • Remove one 7 mm Phillips #1 screw from the center bottom of backplate.
  5. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 5, imagen 1 de 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 5, imagen 2 de 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 5, imagen 3 de 3
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  6. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 6, imagen 1 de 1
    • Peal back metallic tape on the right side of the USB port.
  7. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 7, imagen 1 de 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 7, imagen 2 de 2
    • Remove three 6 mm Phillips #1 screws.
  8. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 8, imagen 1 de 1
    • Use the tip of the spudger or your fingernail to gently push out the white connector.
  9. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 9, imagen 1 de 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 9, imagen 2 de 2
    • Remove the battery from the device.
  10. MSI GS66 Stealth 11UE-007 Speakers Replacement, Speakers: paso 10, imagen 1 de 2 MSI GS66 Stealth 11UE-007 Speakers Replacement, Speakers: paso 10, imagen 2 de 2
    • Disconnect the speaker power using the tip of the spudger or fingernail to gently push on either side of the connector.
  11. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 11, imagen 1 de 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 11, imagen 2 de 2
    • Lift up the clip using the spudger.
    • Pull out the ribbon cable away from the clips.
  12. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 12, imagen 1 de 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 12, imagen 2 de 2
    • Remove the wire from the channel it's sitting in.
  13. MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 13, imagen 1 de 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 13, imagen 2 de 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: paso 13, imagen 3 de 3
    • Lift up the left and right speakers.
Conclusión
Una persona más ha completado esta guía.
Alex Robinson
Miembro Desde 09/06/23
1,061 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 214
