Saltar al contenido principal
MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement
Qué necesitas
  1. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: paso 2, imagen 1 de 1
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: paso 3, imagen 1 de 2 MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: paso 3, imagen 2 de 2
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, Battery: paso 4, imagen 1 de 1
    • Pull the back panel off.
  5. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: paso 5, imagen 1 de 1
    • Notice the L-shaped battery in the lower right corner of the opened laptop.
    • Disconnect the battery from the slot it is connected to. You'll need to push on the sides of the clip and pull.
  6. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: paso 6, imagen 1 de 2 MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: paso 6, imagen 2 de 2
    • Lift up the battery with your fingers and remove it from the laptop.
    • Place the battery away from the laptop in a safe spot and insert your new battery by hooking it up to the slot you previously disconnected the old battery from.
  7. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, MotherBoard: paso 7, imagen 1 de 1
    • Unscrew the 4 1.2mm Phillips #0 screws connecting the motherboard to the laptop case.
    • Disconnect the wires connecting to the motherboard to the USB ports.
    • Disconnect the ribbon cables connecting the keyboard, and track pad of the device.
  8. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: paso 8, imagen 1 de 1
    • Lift the motherboard up and out of the device casing.
  9. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, RAM Cards: paso 9, imagen 1 de 1
    • Lift the motherboard around.
    • You'll notice the RAM cards located where the red box is shown.
  10. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: paso 10, imagen 1 de 1
    • Pull the silver latches to release the RAM cards.
    • Pull out the cards and replace them with new ones.
Conclusión
Stephen Felix
Miembro Desde 10/20/17
207 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 513
