Introducción
This guide demonstrates how to replace the Solid State Drive (SSD) in the MSI GP62MVR 6RF Leopard Pro laptop. It is a simple process with no special skills required. Avoid touching the circuitry when the case is open to avoid short-circuiting components or shocking yourself. If the SSD is full and storage needs to be expanded or it has been corrupted, then the SSD should be be replaced. Follow this guide to change the SSD in a MSI GP62MVR 6RF Leopard Pro. Also be sure to back up any data on the current SSD before replacing it.
Qué necesitas
Place the laptop upside down.
Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
