Introducción
This guide demonstrates how to replace the battery in the MSI GP62MVR 6RF Leopard Pro laptop. It is a simple process with no special skills required. Avoid touching the circuitry when the case is open to avoid short-circuiting components or shocking yourself. If the battery in your laptop doesn’t turn on, cannot charge, or loses charge rapidly, then it will need to be replaced. Follow this guide to change the battery in a MSI GP62MVR 6RF Leopard Pro.
Qué necesitas
Place the laptop upside down.
Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
Remove the battery from the device.
Una persona más ha completado esta guía.
