Saltar al contenido principal
MSI GP60 2PE Leopard Hard Drive Replacement
Qué necesitas
  1. MSI GP60 2PE Leopard Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Flip MSI GP60 2PE Leopard, so that the back is facing up.
  2. MSI GP60 2PE Leopard Hard Drive Replacement: paso 2, imagen 1 de 1
    • Find the unlock tab located on the upper right side of the device, then slide it to the right.
  3. MSI GP60 2PE Leopard Hard Drive Replacement: paso 3, imagen 1 de 3 MSI GP60 2PE Leopard Hard Drive Replacement: paso 3, imagen 2 de 3 MSI GP60 2PE Leopard Hard Drive Replacement: paso 3, imagen 3 de 3
    • Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
  4. MSI GP60 2PE Leopard Hard Drive Replacement: paso 4, imagen 1 de 3 MSI GP60 2PE Leopard Hard Drive Replacement: paso 4, imagen 2 de 3 MSI GP60 2PE Leopard Hard Drive Replacement: paso 4, imagen 3 de 3
    • While holding the release tab, remove the battery slowly.
  5. MSI GP60 2PE Leopard Hard Drive Replacement, Back Panel: paso 5, imagen 1 de 1
    • Flip the device over so the back is facing up.
  6. MSI GP60 2PE Leopard Hard Drive Replacement: paso 6, imagen 1 de 2 MSI GP60 2PE Leopard Hard Drive Replacement: paso 6, imagen 2 de 2
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  7. MSI GP60 2PE Leopard Hard Drive Replacement: paso 7, imagen 1 de 2 MSI GP60 2PE Leopard Hard Drive Replacement: paso 7, imagen 2 de 2
    • Once all four screws are removed, lift the back off.
  8. MSI GP60 2PE Leopard Hard Drive Replacement, Hard Drive: paso 8, imagen 1 de 1
    • Remove the two 5 mm black screws on the right hand side with a Phillips #0 screwdriver.
  9. MSI GP60 2PE Leopard Hard Drive Replacement: paso 9, imagen 1 de 3 MSI GP60 2PE Leopard Hard Drive Replacement: paso 9, imagen 2 de 3 MSI GP60 2PE Leopard Hard Drive Replacement: paso 9, imagen 3 de 3
    • Lift the hard drive, then remove from the device. There is a black strip of plastic attached to make the process easier.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 1,368
