Saltar al contenido principal
Introducción
Looking to replace your fan? This guide will help you do so with only a couple steps.
Partes
No se especificaron partes.
  1. Flip the device over so the back is facing up.
    • Flip the device over so the back is facing up.
  2. Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver. There is a screw located under the battery; lift the battery up to access it.
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  3. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  4. Once all four screws are removed, lift the back off. Once all four screws are removed, lift the back off.
    • Once all four screws are removed, lift the back off.
  5. Remove the  three 5 mm screws from the fan with a Phillips #00 screwdriver. Remove the  three 5 mm screws from the fan with a Phillips #00 screwdriver.
    • Remove the three 5 mm screws from the fan with a Phillips #00 screwdriver.
  6. Pull the wire on the bottom left of the fan out of the socket. Pull the wire gently; pulling too hard could damage the wire. Pull the wire gently; pulling too hard could damage the wire.
    • Pull the wire on the bottom left of the fan out of the socket.
    • Pull the wire gently; pulling too hard could damage the wire.
  7. Remove the fan. Remove the fan.
    • Remove the fan.
Conclusión
2 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 28
Todo El Tiempo: 311
