Saltar al contenido principal
MSI GE72 6QF Apache Pro SSD Replacement
Qué necesitas
  1. MSI GE72 6QF Apache Pro SSD Replacement, Battery: paso 1, imagen 1 de 2 MSI GE72 6QF Apache Pro SSD Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro SSD Replacement: paso 2, imagen 1 de 1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro SSD Replacement: paso 3, imagen 1 de 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro SSD Replacement: paso 4, imagen 1 de 2 MSI GE72 6QF Apache Pro SSD Replacement: paso 4, imagen 2 de 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro SSD Replacement: paso 5, imagen 1 de 2 MSI GE72 6QF Apache Pro SSD Replacement: paso 5, imagen 2 de 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro SSD Replacement: paso 6, imagen 1 de 2 MSI GE72 6QF Apache Pro SSD Replacement: paso 6, imagen 2 de 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro SSD Replacement, SSD: paso 7, imagen 1 de 2 MSI GE72 6QF Apache Pro SSD Replacement, SSD: paso 7, imagen 2 de 2
    • Remove the single 5.5mm Phillips #1 screw attaching the SSD to the laptop.
  8. MSI GE72 6QF Apache Pro SSD Replacement: paso 8, imagen 1 de 2 MSI GE72 6QF Apache Pro SSD Replacement: paso 8, imagen 2 de 2
    • Pull out the SSD by gently wiggling it from side to side until it comes out.
    • If the old SSD you removed contains the operating system, then the new SSD must also contain an operating system.
Conclusión
7 personas más completaron esta guía.
Tanmay Kumar
Miembro Desde 04/17/17
458 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S14-G4, Banghart Spring 2017 Miembro de Cal Poly, Team S14-G4, Banghart Spring 2017
CPSU-BANGHART-S17S14G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 51
Todo El Tiempo: 7,664
