Saltar al contenido principal
MSI GE62 Apache Pro 004 Screen Replacement
Qué necesitas
  1. MSI GE62 Apache Pro 004 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Screen Replacement: paso 2, imagen 1 de 2 MSI GE62 Apache Pro 004 Screen Replacement: paso 2, imagen 2 de 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Screen Replacement: paso 3, imagen 1 de 3 MSI GE62 Apache Pro 004 Screen Replacement: paso 3, imagen 2 de 3 MSI GE62 Apache Pro 004 Screen Replacement: paso 3, imagen 3 de 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Screen Replacement, Screen: paso 4, imagen 1 de 2 MSI GE62 Apache Pro 004 Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Open the laptop up as if you were going to use it.
    • Wedge a spudger in between the screen bezel and work it around to separate it.
  5. MSI GE62 Apache Pro 004 Screen Replacement: paso 5, imagen 1 de 1
    • Remove the screws holding in the screen at the corners with a PH1 screwdriver.
    • Be very careful as the screen may tilt forward so make sure your hand is right is on the screen when the screw comes off.
  6. MSI GE62 Apache Pro 004 Screen Replacement: paso 6, imagen 1 de 3 MSI GE62 Apache Pro 004 Screen Replacement: paso 6, imagen 2 de 3 MSI GE62 Apache Pro 004 Screen Replacement: paso 6, imagen 3 de 3
    • Remove the bezel from the screen.
    • Remove the two screws located at the bottom of the screen using the PH1 screwdriver.
Conclusión
Samer Soukieh
Miembro Desde 02/19/18
209 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S15-G5, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 2,095
