Saltar al contenido principal
MSI GE62 Apache Pro 004 Motherboard Replacement
Qué necesitas
  1. MSI GE62 Apache Pro 004 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Motherboard Replacement: paso 2, imagen 1 de 2 MSI GE62 Apache Pro 004 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Motherboard Replacement: paso 3, imagen 1 de 3 MSI GE62 Apache Pro 004 Motherboard Replacement: paso 3, imagen 2 de 3 MSI GE62 Apache Pro 004 Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
  5. MSI GE62 Apache Pro 004 Motherboard Replacement: paso 5, imagen 1 de 3 MSI GE62 Apache Pro 004 Motherboard Replacement: paso 5, imagen 2 de 3 MSI GE62 Apache Pro 004 Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
    • Unfasten the 8 screws holding the motherboard in place.
    • Pull out the motherboard.
Conclusión
Alexander
Miembro Desde 02/19/18
86 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S15-G5, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Miembros
5 Guías creadas
Un comentario
Hi,can i change msi ge62 6qf motherboard with ge62 7rd apache pro?
Its essential for me.tnx.
rahim dargahi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 1,967
