Saltar al contenido principal
MSI GE62 Apache Pro 004 Battery Replacement
Qué necesitas
  1. MSI GE62 Apache Pro 004 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Battery Replacement: paso 2, imagen 1 de 2 MSI GE62 Apache Pro 004 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Battery Replacement: paso 3, imagen 1 de 3 MSI GE62 Apache Pro 004 Battery Replacement: paso 3, imagen 2 de 3 MSI GE62 Apache Pro 004 Battery Replacement: paso 3, imagen 3 de 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
Conclusión
6 personas más completaron esta guía.
Arian Arana
Miembro Desde 02/13/18
187 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S15-G5, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 28
Todo El Tiempo: 12,646
