Saltar al contenido principal
MSI GE62 6QF Apache Pro RAM Replacement
Qué necesitas
  1. MSI GE62 6QF Apache Pro  RAM Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro  RAM Replacement: paso 2, imagen 1 de 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro  RAM Replacement, Bottom Case: paso 3, imagen 1 de 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro  RAM Replacement: paso 4, imagen 1 de 3 MSI GE62 6QF Apache Pro  RAM Replacement: paso 4, imagen 2 de 3 MSI GE62 6QF Apache Pro  RAM Replacement: paso 4, imagen 3 de 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro  RAM Replacement: paso 5, imagen 1 de 2 MSI GE62 6QF Apache Pro  RAM Replacement: paso 5, imagen 2 de 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro  RAM Replacement, Battery: paso 6, imagen 1 de 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: paso 6, imagen 2 de 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: paso 6, imagen 3 de 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro  RAM Replacement, RAM: paso 7, imagen 1 de 2 MSI GE62 6QF Apache Pro  RAM Replacement, RAM: paso 7, imagen 2 de 2
    • Pull the metal tabs that hold the RAM in place away horizontally from the RAM stick, and slide the RAM out of the socket.
    • Repeat the same steps for the other RAM stick.
Conclusión
Juan Erquiaga
Miembro Desde 09/26/17
107 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S2-G3, Passmore Fall 2017 Miembro de USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 18
Todo El Tiempo: 1,889
