Saltar al contenido principal
MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement
Qué necesitas
  1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement, Faucet: paso 1, imagen 1 de 1
    • Turn the water shutoff valve underneath the sink downwards to stop the flow of water.
  2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 2, imagen 1 de 1
    • Turn the tap(s) on to release any pressure build-up in the pipes.
  3. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 3, imagen 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 3, imagen 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 3, imagen 3 de 3
    • With pliers, unscrew the mounting nuts underneath the sink by turning them counterclockwise.
  4. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 4, imagen 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 4, imagen 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 4, imagen 3 de 3
    • With an adjustable wrench, unscrew the bolts connecting the faucet pipes to the supply lines.
    • After unscrewing the bolts, the faucet pipes should easily come off.
  5. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 5, imagen 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 5, imagen 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 5, imagen 3 de 3
    • Disconnect the lift rod for the drain plug by pushing it off the metal rod.
  6. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 6, imagen 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 6, imagen 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 6, imagen 3 de 3
    • After everything is completely disconnected, pull the faucet out from the top.
  7. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 7, imagen 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 7, imagen 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 7, imagen 3 de 3
    • Clean the area in which the replacement faucet will be placed to ensure that there is a flat surface.
  8. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 8, imagen 1 de 2 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 8, imagen 2 de 2
    • Insert the pipes of the replacement faucet through the sink holes.
    • Each pipe will correspond to each hole on the right and left.
  9. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 9, imagen 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 9, imagen 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 9, imagen 3 de 3
    • With pliers, tighten the mounting nuts underneath the sink in the same location they were removed from.
  10. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 10, imagen 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 10, imagen 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 10, imagen 3 de 3
    • Reattach the faucet pipes to the supply lines and tighten the bolts with an adjustable wrench.
    • Tighten the left and the right pipe.
  11. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 11, imagen 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 11, imagen 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 11, imagen 3 de 3
    • Reattach the lift rod for the drain plug by lining up the holes and pushing it through the metal rod.
  12. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 12, imagen 1 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 12, imagen 2 de 3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 12, imagen 3 de 3
    • Turn the shutoff valve upwards to line it up with the pipe and resume the flow of water.
  13. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: paso 13, imagen 1 de 1
    • Turn on the tap and inspect for leakage. If any leakage does appear, refer to step 1 & 10 and make the pipe bolts tighter.
    • Otherwise, the replacement sink is completely installed.
Conclusión
To remove the replacement faucet, follow steps 1-6.
Manahal Khalil
Miembro Desde 09/11/21
217 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 888
