Saltar al contenido principal
MFC-J4410DW Ink Absorber Box Replacement
Qué necesitas
  1. MFC-J4410DW Ink Absorber Box Replacement, Preparation: paso 1, imagen 1 de 3 MFC-J4410DW Ink Absorber Box Replacement, Preparation: paso 1, imagen 2 de 3 MFC-J4410DW Ink Absorber Box Replacement, Preparation: paso 1, imagen 3 de 3
    • Before beginning disassembly, turn off the printer and unplug the power cord.
    • Open the front access door and remove any cards or cables present. Close the access door.
    • Remove the paper tray.
    • Remove the ink cartridges.
    • You may wish to install the Protective Part to prevent the ink tubes from drying while the cartridges are removed.
    • Open the printer cover using the finger holds on the sides.
    • Unplug and remove any cords present under the cover.
    • Remove the LAN port and EXT port caps (if present).
  2. MFC-J4410DW Ink Absorber Box Replacement, Removing the cover support: paso 2, imagen 1 de 3 MFC-J4410DW Ink Absorber Box Replacement, Removing the cover support: paso 2, imagen 2 de 3 MFC-J4410DW Ink Absorber Box Replacement, Removing the cover support: paso 2, imagen 3 de 3
    • While holding the cover with one hand, pull the hook on the back of the support damper, then remove the damper from the cover.
    • Remove the damper from the support.
    • Turn the support upright and pull it straight out of the printer.
  3. MFC-J4410DW Ink Absorber Box Replacement, Removing the harness cover: paso 3, imagen 1 de 2 MFC-J4410DW Ink Absorber Box Replacement, Removing the harness cover: paso 3, imagen 2 de 2
    • Use your finger or a spudger to unhook the two tabs on the right side of the harness cover by levering it up.
    • Remove the harness cover. There are two tabs on the left side that you have to wiggle free, and one on the front.
  4. MFC-J4410DW Ink Absorber Box Replacement, Removing the grounding screw: paso 4, imagen 1 de 1
    • Remove the 6 mm Phillips #2 screw from the grounding wire of the ADF motor harness.
    • Torque: 0.40±0.10 N•m
    • The Brother service manual lists torques for all screws, but proper torque should not be necessary.
  5. MFC-J4410DW Ink Absorber Box Replacement: paso 5, imagen 1 de 1
    • In the proceeding steps, you will disconnect the following cables:
    • CIS flat cable
    • Scanner motor harness
    • ADF motor harness
    • Document detection/document scanning position sensor harness
  6. MFC-J4410DW Ink Absorber Box Replacement: paso 6, imagen 1 de 1
    • Pull the CIS flat cable out of its socket.
    • Pull all flat cables directly up out of their sockets, pulling on the cables themselves at the blue tabs.
  7. MFC-J4410DW Ink Absorber Box Replacement: paso 7, imagen 1 de 1
    • Pull the scanner motor harness out of its socket.
  8. MFC-J4410DW Ink Absorber Box Replacement: paso 8, imagen 1 de 1
    • Pull the ADF motor harness out of its socket.
  9. MFC-J4410DW Ink Absorber Box Replacement: paso 9, imagen 1 de 1
    • Pull the document detection/document scanning position sensor harness out of its sockets.
  10. MFC-J4410DW Ink Absorber Box Replacement, Opening the scanner harness holder: paso 10, imagen 1 de 2 MFC-J4410DW Ink Absorber Box Replacement, Opening the scanner harness holder: paso 10, imagen 2 de 2
    • Insert a spudger between the scanner harness holder and frame to release the tab. There is a second tab on the opposite side.
    • Lift the scanner harness holder out of its frame.
    • Reassembly Note: Before reattaching the harness holder, it is advisable to reattach the cover support (Step 2) to minimize tension on the wiring harnesses.
  11. MFC-J4410DW Ink Absorber Box Replacement, Securing the scanner harness holder: paso 11, imagen 1 de 2 MFC-J4410DW Ink Absorber Box Replacement, Securing the scanner harness holder: paso 11, imagen 2 de 2
    • Push on the tab to secure the scanner harness holder to the scanner cover.
    • De-route the document detection/document scanning position sensor harness and the ADF motor harness from the scanner harness holder.
    • During reassembly, put a 20mm-thick pad (book, stack of paper) on the scanner glass, close the scanner cover, then route the document detection/document scanning position sensor harness and the ADF motor harness through the harness holder. This will ensure the proper harness tension to allow scanning of thick books.
  12. MFC-J4410DW Ink Absorber Box Replacement, Removing the scanner cover: paso 12, imagen 1 de 1
    • Using both hands, pull the scanner cover to the rear while holding it vertically, then lift it off of the printer.
  13. MFC-J4410DW Ink Absorber Box Replacement, Removing the upper cover: paso 13, imagen 1 de 2 MFC-J4410DW Ink Absorber Box Replacement, Removing the upper cover: paso 13, imagen 2 de 2
    • Remove the six 12 mm Phillips #2 screws securing the upper cover to the printer.
    • Torque: 0.70±0.10 N•m
    • Pull off the upper cover.
    • When reinstalling, ensure that the control panel wiring holder slides into its slot on the upper cover.
  14. MFC-J4410DW Ink Absorber Box Replacement, Removing the ink absorber box wiring: paso 14, imagen 1 de 2 MFC-J4410DW Ink Absorber Box Replacement, Removing the ink absorber box wiring: paso 14, imagen 2 de 2
    • Remove the ink absorber full sensor from its socket.
    • De-route the wiring from its harness.
  15. MFC-J4410DW Ink Absorber Box Replacement, Unhooking the ink absorber: paso 15, imagen 1 de 1
    • Unclip the ink absorber from the harness by pulling it up and to the right.
  16. MFC-J4410DW Ink Absorber Box Replacement, Removing the tubes: paso 16, imagen 1 de 3 MFC-J4410DW Ink Absorber Box Replacement, Removing the tubes: paso 16, imagen 2 de 3 MFC-J4410DW Ink Absorber Box Replacement, Removing the tubes: paso 16, imagen 3 de 3
    • For this step, spin the printer around so the back is toward you.
    • Remove the drain tube and the air vent tube from the ink absorber box. A spudger may be helpful.
    • Clip the ends of the tubes so they won't leak.
    • De-route the tubes from the holder.
  17. MFC-J4410DW Ink Absorber Box Replacement, Removing the ink absorber box: paso 17, imagen 1 de 1
    • Rotate the ink absorber box 90º vertically, and pull it up out of its socket.
Conclusión
To reassemble your device, follow these instructions in reverse order. You may also wish to replace the flushing box at this time.
Screw torques from the service manual have been included if you happen to have a torque screwdriver, but don’t worry about them if you don’t.
After reassembly, follow the following steps to reset the purge count in order to clear the “Ink Absorber Full” error:
  1. Plug the printer in and turn it on.
  2. Press the Home button (the house icon) on the front of the printer until the Maintenance Mode screen appears (approximately five seconds).
  3. Hold down the blank button at the bottom of the screen until a number keypad appears on the screen (approximately two seconds).
  4. Press *286 and 4 (you can use the onscreen keypad or the printer’s built-in keypad for this). The printer will beep and MAINTENANCE will appear on the screen.
  5. Press 8 and 0.
  6. Press the down arrow repeatedly until PURGE: (or FLUSHING:) appears on the screen.
  7. Press 278 and 3. The printer will beep and MAINTENANCE will again appear on the screen.
  8. Press 9 twice to exit maintenance mode and reboot the printer. You can also use this to start over if you make an error.
50 personas más completaron esta guía.
Calion
Miembro Desde 12/24/10
3,178 Reputación
3 Guías creadas
Equipo
Syler Solutions Miembro de Syler Solutions
Business
1 Miembro
12 Guías creadas
51 comentarios
Useful for dismantling the printer although my problem wasn’t with the waste ink component
Rob Hindle - Contestar
Well, feel free to make a guide based on this one for whatever your problem was!
Calion -
Calion, you are my hero! The one place I’ve found where I can buy the replacement waste box for my Brother MFC-J4510DW does not provide directions on how to install it. And Brother itself offers neither the part nor the instructions. I thought I was going to have to buy a new printer until I came across your excellent report! Thanks so much for doing this!
haroldsogard - Contestar
You’re welcome! Very glad I could help out!
Calion -
Very informative and helpful :-)
Question could you fit a external waste ink tank ? what size are the waste ink tubes?
George Duthie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 38
Ultimos 7 días: 295
Ultimos 30 días: 1,535
Todo El Tiempo: 47,548
