Saltar al contenido principal
MAGNAVOX MDV2300 Power Cord Replacement
Qué necesitas
  1. MAGNAVOX MDV2300 Power Cord Replacement, Power Cord: paso 1, imagen 1 de 1
    • Make sure the device is unplugged from the wall.
  2. MAGNAVOX MDV2300 Power Cord Replacement: paso 2, imagen 1 de 1
    • Unscrew the two screws that hold together the top panel.
  3. MAGNAVOX MDV2300 Power Cord Replacement: paso 3, imagen 1 de 1
    • Remove the top panel.
  4. MAGNAVOX MDV2300 Power Cord Replacement: paso 4, imagen 1 de 1
  5. MAGNAVOX MDV2300 Power Cord Replacement: paso 5, imagen 1 de 2 MAGNAVOX MDV2300 Power Cord Replacement: paso 5, imagen 2 de 2
    • Remove disc drive by unscrewing the 2 screws that hold the drive in place.
  6. MAGNAVOX MDV2300 Power Cord Replacement: paso 6, imagen 1 de 1
    • Identify the power cord.
    • The cord must either be too short or torn to warrant replacement.
  7. MAGNAVOX MDV2300 Power Cord Replacement: paso 7, imagen 1 de 1
    • Cut the old wire out from the chip.
    • Attach the new wire into the housing.
    • Line up new wire with the appropriate holes and solder to board.
    • The white wire will be your neutral and the black wire will be your negative. View link of how to solder in order to replace the power cord. http://www.instructables.com/id/How-to-s...
Conclusión
After soldering, let cool and then reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Justin
Miembro Desde 01/21/15
298 Reputación
2 Guías creadas
Equipo
Penn State, Team 1-41, Kaschak Winter 2015 Miembro de Penn State, Team 1-41, Kaschak Winter 2015
PSU-KASCHAK-W15S1G41
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 534
