Introducción
This guide will show how to open the device and remove the z-axis belt. This is the largest belt that goes around all 4 of the threaded z-axis rods at each corner of the printer. While no tools are required for this process, care needs to be taken in order to keep the Z rods vertical to ensure proper realignment of the belt and easy reassembly.
Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
Remove the z axis belt from the device by simply lifting each corner of the belt off the corner gears and slide up over the z axis bars.
Un comentario
Need a replacement z axis belt for my M3D micro printer don’t know where to go to get one
