Saltar al contenido principal
Lytro Camera First Generation Repair
Qué necesitas
  1. Lytro Camera First Generation Repair, Lytro Camera First Generation Lens: paso 1, imagen 1 de 1
    • Pull the top off using your hands or the plastic opening tool.
  2. Lytro Camera First Generation Repair: paso 2, imagen 1 de 1
    • Unscrew the four screws(7.1cm) seen after taking the top off.
  3. Lytro Camera First Generation Repair: paso 3, imagen 1 de 1
    • Pry that silver piece off that you just took the four screws out of.
  4. Lytro Camera First Generation Repair: paso 4, imagen 1 de 1
    • Take the camera out of the red part. You should have 3 piece not including the top.
  5. Lytro Camera First Generation Repair: paso 5, imagen 1 de 1
    • Take the 3 screws(.5) out of the middle piece.
  6. Lytro Camera First Generation Repair: paso 6, imagen 1 de 1
    • After taking that off you will see the camera lens.
  7. Lytro Camera First Generation Repair: paso 7, imagen 1 de 1
    • Pry the piece hanging off with tweezers.
  8. Lytro Camera First Generation Repair: paso 8, imagen 1 de 1
    • Now you can unscrew the three screws(.5) seen releasing the camera lense from the camera.
  9. Lytro Camera First Generation Repair: paso 9, imagen 1 de 1
    • After that you can pull it off with the tweezers.
  10. Lytro Camera First Generation Repair: paso 10, imagen 1 de 1
    • Now that you have it off you can replace it and reverse the steps getting it back together.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 392
