Saltar al contenido principal
Lumen Projector Bulb Replacement
Qué necesitas
  1. Lumen Projector Bulb Replacement, Unplug projector: paso 1, imagen 1 de 1
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Lumen Projector Bulb Replacement: paso 2, imagen 1 de 1
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Lumen Projector Bulb Replacement: paso 3, imagen 1 de 1
    • Unscrew the bulb screws on either side of the silver plate.
  4. Lumen Projector Bulb Replacement: paso 4, imagen 1 de 1
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Lumen Projector Bulb Replacement: paso 5, imagen 1 de 1
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Lumen Projector Bulb Replacement: paso 6, imagen 1 de 1
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Lumen Projector Bulb Replacement: paso 7, imagen 1 de 1
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Lumen Projector Bulb Replacement: paso 8, imagen 1 de 1
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Lumen Projector Bulb Replacement: paso 9, imagen 1 de 1
    • Dispose of the bulb by sending it to a recycling center.
Conclusión
Una persona más ha completado esta guía.
Desiree Benitez
Miembro Desde 01/21/17
128 Reputación
1 Guía escrita
Equipo
Un comentario
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 761
