Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
This guide will show how to lubricate the volume slider after you have opened up the base of the phone. Your volume slider will operate smooth after completing this guide.
  1. Unplug the device before proceeding. Using a plastic opening tool, remove the phone cord from the phone jack from the base of the headset.
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack from the base of the headset.
  2. Remove the phone cord screw cap. Unscrew the 7.5mm screw. Remove the screw cap.
    • Remove the phone cord screw cap.
    • Unscrew the 7.5mm screw.
    • Remove the screw cap.
    • Remove the cord from the phone base.
  3. Use finger to remove the battery cover. Use finger to remove the battery cover.
    • Use finger to remove the battery cover.
  4. Remove the Volume Dial by gently grasping the dial and pulling away from the base. Remove the Volume Dial by gently grasping the dial and pulling away from the base.
    • Remove the Volume Dial by gently grasping the dial and pulling away from the base.
  5. Remove the 6 screws from the base shell.
    • Remove the 6 screws from the base shell.
    • Remove the 3 12mm screws with the Philips head #1 screw driver.
    • Remove the 3 18mm screws with the Philips head #1 screw driver.
  6. Pry off the base shell using a Plastic Opener Tool. Pry off the base shell using a Plastic Opener Tool.
    • Pry off the base shell using a Plastic Opener Tool.
  7. Turn the tuning slider counter clockwise all they way. Apply lubricant to slider rail
    • Turn the tuning slider counter clockwise all they way.
    • Apply lubricant to slider rail
    • Turn the tuning slider back and forth to distribute lubricant
    • CAUTION: Make sure lubricant does not circuit board. This can damage the circuit board.
Conclusión
Alles Rebel
Miembro Desde 20/09/12
72 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 16-59, Forte Fall 2012 Miembro de Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 600
