Saltar al contenido principal
Lubricate General Electric Telephone 2-9710A Power Dial
Qué necesitas
  1. Lubricate General Electric Telephone 2-9710A Power Dial, Phone Cord: paso 1, imagen 1 de 2 Lubricate General Electric Telephone 2-9710A Power Dial, Phone Cord: paso 1, imagen 2 de 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Lubricate General Electric Telephone 2-9710A Power Dial: paso 2, imagen 1 de 3 Lubricate General Electric Telephone 2-9710A Power Dial: paso 2, imagen 2 de 3 Lubricate General Electric Telephone 2-9710A Power Dial: paso 2, imagen 3 de 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Lubricate General Electric Telephone 2-9710A Power Dial, 9V Base Battery: paso 3, imagen 1 de 2 Lubricate General Electric Telephone 2-9710A Power Dial, 9V Base Battery: paso 3, imagen 2 de 2
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. Lubricate General Electric Telephone 2-9710A Power Dial, Remove Volume Dial: paso 4, imagen 1 de 2 Lubricate General Electric Telephone 2-9710A Power Dial, Remove Volume Dial: paso 4, imagen 2 de 2
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. Lubricate General Electric Telephone 2-9710A Power Dial, Remove Screws on the Back: paso 5, imagen 1 de 1
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. Lubricate General Electric Telephone 2-9710A Power Dial, Pry the Back Off: paso 6, imagen 1 de 2 Lubricate General Electric Telephone 2-9710A Power Dial, Pry the Back Off: paso 6, imagen 2 de 2
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
  7. Lubricate General Electric Telephone 2-9710A Power Dial, Lubricate General Electric Telephone 2-9710A Power Dial: paso 7, imagen 1 de 1
    • Inside the base shell on the circuit board, lubricate the power switch.
    • Make sure the lubricant does not get on the circuit board. This can damage the circuit board.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 16-59, Forte Fall 2012 Miembro de Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 877
