Introducción
I thought I was going to have to pay $150 to replace my MacBook's bottom cover. Then I found this link on the apple community pages. Hope this helps
  1. Apple has determined that under certain circumstances the rubber surface on some MacBooks may separate from the bottom case of the system. MacBooks shipped between October 2009 and April 2011 may experience this issue.  Apple will replace the bottom case of any affected MacBook, free of charge, that exhibits the issue.
    • Apple has determined that under certain circumstances the rubber surface on some MacBooks may separate from the bottom case of the system. MacBooks shipped between October 2009 and April 2011 may experience this issue. Apple will replace the bottom case of any affected MacBook, free of charge, that exhibits the issue.
    • Bottom Case Replacement Process You may choose from three options to get a replacement bottom case for your MacBook. In all cases, your MacBook serial number will be checked to verify that it is eligible for this program.
  2. Visit an Apple Retail Store - Set up an appointment with a Genius.
    • Visit an Apple Retail Store - Set up an appointment with a Genius.
    • Visit an Apple Authorized Service Provider
    • Order a replacement bottom case kit online. Receive a kit that includes a new bottom case, screws, a Phillips head screwdriver, and instructions for how to remove the current bottom case and install the new one. If you feel comfortable with the self-service option, you can place your order via the web. https://supportform.apple.com/201105/
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Additional Information If you believe you have paid for a repair or replacement due to this issue, contact Apple regarding a refund.
    • Additional Information If you believe you have paid for a repair or replacement due to this issue, contact Apple regarding a refund.
  5. This worldwide Apple program does not extend the standard warranty coverage of the affected MacBook.  This program covers affected MacBooks for FOUR years from original purchase date. Apple will continue to evaluate the service data and will provide further extensions to this program as needed.
    • This worldwide Apple program does not extend the standard warranty coverage of the affected MacBook. This program covers affected MacBooks for FOUR years from original purchase date. Apple will continue to evaluate the service data and will provide further extensions to this program as needed.
Conclusión
I accidentally came across this. Thought I would share, in case others were having the same problem.
2 personas más completaron esta guía.
Gamzee Makara
Miembro Desde 16/08/13
242 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 1,667
