Saltar al contenido principal
Lorex LW2742 Speaker Replacement
Qué necesitas
  1. Lorex LW2742 Speaker Replacement, Back Panel: paso 1, imagen 1 de 3 Lorex LW2742 Speaker Replacement, Back Panel: paso 1, imagen 2 de 3 Lorex LW2742 Speaker Replacement, Back Panel: paso 1, imagen 3 de 3
    • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
    • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
  2. Lorex LW2742 Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
  3. Lorex LW2742 Speaker Replacement: paso 3, imagen 1 de 2 Lorex LW2742 Speaker Replacement: paso 3, imagen 2 de 2
    • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
    • Carefully remove the back panel
    • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
  4. Lorex LW2742 Speaker Replacement, Speaker: paso 4, imagen 1 de 3 Lorex LW2742 Speaker Replacement, Speaker: paso 4, imagen 2 de 3 Lorex LW2742 Speaker Replacement, Speaker: paso 4, imagen 3 de 3
    • Locate the motherboard and carefully pull the red and black speaker wires out of their harness.
  5. Lorex LW2742 Speaker Replacement: paso 5, imagen 1 de 2 Lorex LW2742 Speaker Replacement: paso 5, imagen 2 de 2
    • Using a metal spudger, pry the melted black plastic away from the speaker.
    • Carefully pull the speaker out of its housing by the wires.
Conclusión
Una persona más ha completado esta guía.
Alex Kusmierz
Miembro Desde 09/26/16
601 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 16-1, Eyestone Fall 2016 Miembro de USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 188
