Saltar al contenido principal
Lorex LW2742 Microphone Replacement
Qué necesitas
  1. Lorex LW2742 Microphone Replacement, Microphone: paso 1, imagen 1 de 2 Lorex LW2742 Microphone Replacement, Microphone: paso 1, imagen 2 de 2
    • Remove the six 10mm Torx T10 screws on camera face.
  2. Lorex LW2742 Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the exterior lens cover.
  3. Lorex LW2742 Microphone Replacement: paso 3, imagen 1 de 3 Lorex LW2742 Microphone Replacement: paso 3, imagen 2 de 3 Lorex LW2742 Microphone Replacement: paso 3, imagen 3 de 3
    • Remove the LED foam ring with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
  4. Lorex LW2742 Microphone Replacement: paso 4, imagen 1 de 1
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the left and right 8mm screws first. Followed by the top and bottom 5mm screws.
  5. Lorex LW2742 Microphone Replacement: paso 5, imagen 1 de 1
  6. Lorex LW2742 Microphone Replacement: paso 6, imagen 1 de 3 Lorex LW2742 Microphone Replacement: paso 6, imagen 2 de 3 Lorex LW2742 Microphone Replacement: paso 6, imagen 3 de 3
    • Use tweezers to disconnect the microphone wires from the internal components of camera.
  7. Lorex LW2742 Microphone Replacement: paso 7, imagen 1 de 3 Lorex LW2742 Microphone Replacement: paso 7, imagen 2 de 3 Lorex LW2742 Microphone Replacement: paso 7, imagen 3 de 3
    • Remove the 4mm Flathead #4 screw on the bottom of the camera.
    • Remove the weatherproof gasket around the microphone with tweezers.
  8. Lorex LW2742 Microphone Replacement: paso 8, imagen 1 de 3 Lorex LW2742 Microphone Replacement: paso 8, imagen 2 de 3 Lorex LW2742 Microphone Replacement: paso 8, imagen 3 de 3
    • Remove the microphone.
    • Push the microphone from the inside out for easier removal.
Conclusión
Alex Kusmierz
Miembro Desde 09/26/16
601 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 16-1, Eyestone Fall 2016 Miembro de USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 259
