Saltar al contenido principal
Lorex LW2742 Lens Replacement
Qué necesitas
  1. Lorex LW2742 Lens Replacement, Lens: paso 1, imagen 1 de 2 Lorex LW2742 Lens Replacement, Lens: paso 1, imagen 2 de 2
    • Remove the six 10mm Torx T10 screws on the camera face.
  2. Lorex LW2742 Lens Replacement: paso 2, imagen 1 de 1
    • Remove the exterior lens cover.
  3. Lorex LW2742 Lens Replacement: paso 3, imagen 1 de 3 Lorex LW2742 Lens Replacement: paso 3, imagen 2 de 3 Lorex LW2742 Lens Replacement: paso 3, imagen 3 de 3
    • Remove the foam ring around the lens with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
  4. Lorex LW2742 Lens Replacement: paso 4, imagen 1 de 1
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the top and bottom 5mm screws first, followed by the left and right 8mm screws.
  5. Lorex LW2742 Lens Replacement: paso 5, imagen 1 de 1
    • Remove the LED board with tweezers.
    • It is unnecessary to unplug the LED board from internal components for lens replacement.
  6. Lorex LW2742 Lens Replacement: paso 6, imagen 1 de 2 Lorex LW2742 Lens Replacement: paso 6, imagen 2 de 2
    • Use the Phillips #000 to remove the three 3mm screws on the face of the camera lens
  7. Lorex LW2742 Lens Replacement: paso 7, imagen 1 de 1
    • Remove the camera lens.
    • After replacing camera lens and before reassembly it is encouraged to clean new lens surface with a microfiber lens cleaning cloth
Conclusión
Alex Kusmierz
Miembro Desde 09/26/16
601 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 16-1, Eyestone Fall 2016 Miembro de USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 902
