Saltar al contenido principal
Longboard Wheel Bearings Maintenance
Qué necesitas
  1. Longboard Wheel Bearings Maintenance, Longboard Wheel Bearings: paso 1, imagen 1 de 2 Longboard Wheel Bearings Maintenance, Longboard Wheel Bearings: paso 1, imagen 2 de 2
    • Remove the wheel components from the axle starting with the cap nut.
    • Set aside the smaller components on a paper towel. They are easy to lose and can leave grime on surfaces.
  2. Longboard Wheel Bearings Maintenance: paso 2, imagen 1 de 2 Longboard Wheel Bearings Maintenance: paso 2, imagen 2 de 2
    • Use the axle to carefully pry each of the bearings out of the inside of the wheel.
  3. Longboard Wheel Bearings Maintenance: paso 3, imagen 1 de 2 Longboard Wheel Bearings Maintenance: paso 3, imagen 2 de 2
    • Remove the rubber seal fitted in the bearings with a thin blade.
    • Make sure to insert the blade between the rubber and metal, otherwise the seal may be damaged. Pry the seal out by moving the tool in the opposite direction of the blade edge and twisting slightly.
  4. Longboard Wheel Bearings Maintenance: paso 4, imagen 1 de 2 Longboard Wheel Bearings Maintenance: paso 4, imagen 2 de 2
    • Place the bearings in a bowl.
    • Add solvent until all the bearings are submerged completely.
  5. Longboard Wheel Bearings Maintenance: paso 5, imagen 1 de 2 Longboard Wheel Bearings Maintenance: paso 5, imagen 2 de 2
    • Let the bearings soak for 2-4 hours.
    • Empty the bowl and allow the bearings to dry for 30 minutes.
    • Keep all the easy-to-lose components in the same area as the bowl used for soaking.
  6. Longboard Wheel Bearings Maintenance: paso 6, imagen 1 de 3 Longboard Wheel Bearings Maintenance: paso 6, imagen 2 de 3 Longboard Wheel Bearings Maintenance: paso 6, imagen 3 de 3
    • Add two drops of lubricant on opposite sides for each bearing.
    • Remount the rubber seals in each bearing now that they are cleaned and lubricated.
  7. Longboard Wheel Bearings Maintenance: paso 7, imagen 1 de 2 Longboard Wheel Bearings Maintenance: paso 7, imagen 2 de 2
    • Wedge each bearing back into the center of the wheel.
  8. Longboard Wheel Bearings Maintenance: paso 8, imagen 1 de 3 Longboard Wheel Bearings Maintenance: paso 8, imagen 2 de 3 Longboard Wheel Bearings Maintenance: paso 8, imagen 3 de 3
    • Remount the wheel components in order: wheel, washer, cap nut.
    • Tighten the cap nut until it provides resistance.
  9. Longboard Wheel Bearings Maintenance: paso 9, imagen 1 de 2 Longboard Wheel Bearings Maintenance: paso 9, imagen 2 de 2
    • Spin the wheel to test the clean bearings.
    • A new set of bearings should allow for roughly 60 seconds of uninterrupted free-spin.
Conclusión
While the fix itself is relatively simple, it requires time to allow the bearings to be cleaned properly. Be mindful of where the smaller components are placed as one can lose track of them easily. Also, be sure to employ caution when using the box cutter.
Alexander Whitworth
Miembro Desde 02/08/19
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 213
