Saltar al contenido principal
Introducción
A soldering kit is necessary to completely isolate the motherboard as we will be needing to desolder the USB and camera joints.
  1. Remove the two 8mm Phillips#0 screws on the back cover. The motherboard is attaching the two covers together, so don't separate them entirely just yet.
    • Remove the two 8mm Phillips#0 screws on the back cover.
    • The motherboard is attaching the two covers together, so don't separate them entirely just yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Remove the four 6mm Phillips#0 screws  connecting the motherboard and front cover. DO NOT detach the wire connecting the motherboard to the front cover.
    • Remove the four 6mm Phillips#0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Grasp the white connector attaching the button chip wire to the motherboard. Grab between the tabs and the socket. Wiggle the connector back and forth to remove it from the connection box
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
  4. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  5. Grasp the white wire connector between the tabs and the socket. Wiggle the connector back and forth to remove the front cover from the motherboard.
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
  6. Grasp the white wire connector on the back of the motherboard to remove the USB cable. Wiggle the connector back and forth to remove it from the socket.
    • Grasp the white wire connector on the back of the motherboard to remove the USB cable.
    • Wiggle the connector back and forth to remove it from the socket.
  7. Desolder the joint on the front of the motherboard to completely detach the USB cable. Follow this link to learn how to properly solder and desolder your parts.
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
  8. Remove the two 8mm Phillips#0 screws on the back of the motherboard.
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
  9. Remove the camera from the motherboard by desoldering the two connections as shown. Follow this link to learn how to properly solder and desolder your parts. Follow this link to learn how to properly solder and desolder your parts.
    • Remove the camera from the motherboard by desoldering the two connections as shown.
Conclusión
Una persona más ha completado esta guía.
Cory Davis
Miembro Desde 14/04/13
236 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 12-34, Amido Spring 2013 Miembro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 6
Todo El Tiempo: 1,485
