Saltar al contenido principal
Logitech Webcam Pro 9000 Microphone Replacement
Qué necesitas
  1. Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: paso 1, imagen 1 de 2 Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: paso 1, imagen 2 de 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Microphone Replacement: paso 2, imagen 1 de 2 Logitech Webcam Pro 9000 Microphone Replacement: paso 2, imagen 2 de 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: paso 3, imagen 1 de 2 Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: paso 3, imagen 2 de 2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
  4. Logitech Webcam Pro 9000 Microphone Replacement, Microphone: paso 4, imagen 1 de 3 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: paso 4, imagen 2 de 3 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: paso 4, imagen 3 de 3
    • Wedge the plastic opening tool into the crack between the plastic cover and microphone guard.
    • Use the wedge to separate the two pieces.
    • It might take more force than expected.
  5. Logitech Webcam Pro 9000 Microphone Replacement: paso 5, imagen 1 de 3 Logitech Webcam Pro 9000 Microphone Replacement: paso 5, imagen 2 de 3 Logitech Webcam Pro 9000 Microphone Replacement: paso 5, imagen 3 de 3
    • Twist the rubber casing and remove it from the plastic cover.
Conclusión
2 personas más completaron esta guía.
nieko
Miembro Desde 04/18/13
63 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-34, Amido Spring 2013 Miembro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 26
Todo El Tiempo: 2,134
