Saltar al contenido principal
Logitech Webcam Pro 9000 Camera Replacement
Qué necesitas
  1. Logitech Webcam Pro 9000 Camera Replacement, Front and Back Cover: paso 1, imagen 1 de 2 Logitech Webcam Pro 9000 Camera Replacement, Front and Back Cover: paso 1, imagen 2 de 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Camera Replacement: paso 2, imagen 1 de 2 Logitech Webcam Pro 9000 Camera Replacement: paso 2, imagen 2 de 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Camera Replacement, Camera: paso 3, imagen 1 de 1
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
  4. Logitech Webcam Pro 9000 Camera Replacement: paso 4, imagen 1 de 3 Logitech Webcam Pro 9000 Camera Replacement: paso 4, imagen 2 de 3 Logitech Webcam Pro 9000 Camera Replacement: paso 4, imagen 3 de 3
    • Remove the camera from the motherboard by desoldering the two connections as shown.
    • Follow this link to learn how to properly solder and desolder your parts.
Conclusión
nieko
Miembro Desde 04/18/13
63 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-34, Amido Spring 2013 Miembro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 2,352
