Saltar al contenido principal
Logitech UE MegaBoom Outer Mesh Replacement
Qué necesitas
  1. Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: paso 1, imagen 1 de 3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: paso 1, imagen 2 de 3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: paso 1, imagen 3 de 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Outer Mesh Replacement: paso 2, imagen 1 de 3 Logitech UE MegaBoom Outer Mesh Replacement: paso 2, imagen 2 de 3 Logitech UE MegaBoom Outer Mesh Replacement: paso 2, imagen 3 de 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Outer Mesh Replacement: paso 3, imagen 1 de 2 Logitech UE MegaBoom Outer Mesh Replacement: paso 3, imagen 2 de 2
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
Conclusión
Una persona más ha completado esta guía.
Oscar Ambriz
Miembro Desde 09/27/17
958 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S9-G2, Banghart Fall 2017 Miembro de Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Miembros
14 Guías creadas
2 comentarios
You know where to buy a replacement mesh in custom colors
Jonathan Lang - Contestar
Bonjour merci pour le tuto mais ou trouve t-on le “outer mesh” de remplacemet????
Merci d’avance
Evan
Evan Castione - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 19
Todo El Tiempo: 3,817
