Introducción
A dead battery can be an inexpensive fix for devices that will not charge, or have a short battery life. This guide will show you how this part can be replaced.
Qué necesitas
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
14 personas más completaron esta guía.
24 comentarios
There is a way to take it apart without all these steps and a complete tear down.
This is huge overkill. Only the bottom cap and circuit board need to be removed for a battery replacement.
I agree. The battery is located on the bottom end only.
Jamin Hu -
^ the person who says that you only need to remove the one end-cap to replace the battery is correct. The process outlined in this article is more likely to damage all the fabric and other end-cap than just opening one end and gently prying it back until you can slide out the battery. FYI, the pull tab on my battery broke right off, and I had to pull it out with pliers.
